LAP does not appear in Cisco Prime Infrastructure
denis.lepage
I just installed Cisco Prime Infrastructure 3.0 for a trial.
I got my two Wireless LAN controlers imported and monitoring them, but no Lightweight access points are imported in the console.  I can see clients connected over the WLAN.
How can I import my LAP into Cisco Prime infrastructure?
8 Replies 8
Hi guys,
When i added my access points they come back as "un-managed" and a yellow triangle with status - "SNMP failure: Failed to perform the SNMP get". As i understand it SNMP is disabled on LAPs controlled by a WLC.
Any help would be great as its been 3 days of me trying to get around this with no luck.
Cheers
MP
denis.lepage
I did a fresh install of Prime infrastructure 3.0 on another IP Range, no firewall between Prime server and WLC controllers, same problem.
I can add WLC controllers, but Lightweight AP are not populating in Prime Infrastructure.
Any help would be appreciate.
marce1000
 - Make sure that you add the controller in prime, with a valid snmp-read community; meaning the same as was specified on the wl-controller; also make sure that the same snmp version is specified on the controller as on Prime
Thanks marce1000, this is already the case, for the snmp community and the snmp version (2c).
Any other idea?
I can easily see my controllers, stats and config about the, WLAN, etc.  But the lightweight APs won't populate into Prime infrastructure.
Can Prime reach your AP(s) or is there a firewall between them.
I can reach directly APs from Prime server.  No firewall present between them.
any solution?
alberto.tanaka
9800-CL works via netconf-yang, I applied it as an explanation of the link and it worked:
https://www.cisco.com/c/pt_br/support/docs/storage-networking/management/200933-YANG-NETCONF-Configuration-Validation.html
validation:
Prime_Infrastructure# ssh <9800_ip_address> <priv15_username> port 830
