Last reset cause: BootFromUpgradeRegFail
gznfr0001
I tried to login one ASR 920-12SZ-IM router but no output came on Putty. Then i try to put router in ROMMON mode to check the IOS it stuck on "Last reset cause: BootFromUpgradeRegFail " doesn't get Rommon> prompt.
What else i can do? please suggest.
I have same problem...too bad the FN-70391 doesn't help at all.  Can't get the router out of the BootFromUpgradeRegFail prompt
The FN wants you to go change boot variable in IOS but I can't get the router to boot or get to any type of prompt or even ROMMON
octavio silva
Same on a ASR920
System Bootstrap, Version 15.6(9r)S, RELEASE SOFTWARE (fc1)
Copyright (c) 2016 by cisco Systems, Inc.
Compiled Tue 12-Jan-16 20:04 by ccai
Starting Initialization of FMAN0
Loading ucode for FMAN0, size: 31424, ver: 106.04.14
Silicon Rev Major:Minor [1:1]
Initializing the pci..
IOFPGA version[17082912]
Boot ROM0
SD card is not presentUEA platform with 1048576 Kbytes of main memory
Resetting upgrade counter from failed upgrade
ERROR: command complete not receivedESDHC Reg Dump: ERR
BLKATTR=0x00010000
CMDARG=0x00000000
XFERTYP=0x123a0037
PRSSTAT=0x0f8d0009
CMDRSP0=0x00000000
CMDRSP1=0x00000000
CMDRSP2=0x00000000
CMDRSP3=0x00000000
PROCTL=0x00000020
SYSCTL=0x000e0008
IRQSTATEN=0x377f11ff
IRQSTAT=0x00000040
IRQSIGEN=0x00000000
WML=0x00100010
HOSTCAPBLT=0x37f20000
File system not supported
boot: error executing "boot asr920igp-universalk9.16.06.06.SPA.bin"
autoboot: boot failed, restarting...
Boot ROM0
Already manage to solve the SDcard not present but still on infinity reboot.
Boot ROM0
Directory asr920igp-universalk9.16.06.06.SPA.bin not found
Unable to locate asr920igp-universalk9.16.06.06.SPA.bin directory
Unable to load asr920igp-universalk9.16.06.06.SPA.bin
