Light weight solution
adeelhamidpk
Community Member
HI
     I am in need of router/layer 3 switch solution with have the following comments. Kindly guide me the integrated solution along with power solution aswell
  1. Ethernet Connections / POE
  2. Fiber Connections
  3. E1s (Transport & Terminate)
  4. Analog lines FXO & FXS
  5. Power Solution
I will appreciate your cooperation for the support and guidance.
Leo Laohoo
How much is the budget?
