link aggregation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
08-06-2024 12:49 AM
Sure! Here's the translation:
"I would like to know if it is possible to have 6 or 12 sub-interfaces in one port channel, and why."
- Labels:
Network Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 12:56 AM - edited 08-06-2024 01:07 AM
Port-channel as physical interface you can have as much as you can of subinterface' and it limit by SW vlan tag if SW vlan support up to 1023 then you can config up to 1023 (except some reserved vlan).
Note:- Some sw support up to 4093 vlan.
MHM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 01:09 AM
I would like to know if it is possible to have 5, 7, or 9 sub-interfaces in one port channel."
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 07:52 AM
Sure no problem at all
MHM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 07:52 AM
As far as I know, port-channel interfaces don't have different limitations vs. other interfaces that support subinterfaces.
As to your OP "why", for the same reasons you would use subinterfaces, although I think it much more likely a L3 switch port-channel would be a trunk using SVIs and unsure a L3 switch would even support subinterfaces.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 08:09 AM
BTW, you're not confusing port-channel physical interfaces with interface logical subinterfaces?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2024 09:09 PM
Okay, thank you for the answer.
I have an additional question. I would like to know if "mode on" is one of the protocols for link aggregation. How is it different from LACP and PAgP? Can it be used with all products?
