linking java to Ciscoworks
colpal
Community Member
I use several web apps where I work. The Cisco app will run on my PC using java 1.3.1; The problem is I need to also use 1.4.1 for my HP Openview. If Ciscoworks will not work with 1.4.1 (I don't know one way or the other I have not loaded it yet) how can I link it to 1.3.1 so I can keep both java versions on my PC? Thanks for your time, folks.
rmushtaq
Level 11
Level 11
If you have the latest CiscoWorks 2.2 bundle, then once you install the Update-1 patch from CCO , it will add support for the new plug-in v1.4.1_02
colpal
Community Member
Thanks rmushtaq for the response. I'm at Common Management Foundation 2.0 so I need to move up. FWIW, I have a workaround. I loaded Sun Java V1.4.1_07 on my PC then using the Java Web tool which loaded with 1.4.1 I switch back and forth between Java versions. I also have to uncheck 1.4.1 in IE advanced settings to get CW2000 to come up.
