LMS 2.5 and ACS 3.3
malvadobladez
I have Cisco Works LMS 2.5 Bundle up and running for a few months now with no issues.
I have installed a new ACS Server with 3.3 and have Cisco Work integrated into ACS.
The problem I am having now is that CS, DFM, IPM, are not picking up the devices that it was able to see before, RME see's all the devices.
Currently I only have 2 devices configured on the new ACS Server for testing, when I run the report from CS on list devices it does not show anything. but if I run the report show all deives not in ACS it show me the entire list.
How can I get the other services to see all these devices? If I remove ACS as the authentication method everything works great.
nhabib
Level 9
Level 9
My understanding is that all the devices need to be in the ACS in order for LMS 2.5 to work.
I seems that way, but I have a few devices configured and they are still not showing up, I have tried to import them from CS it does not pick it up.
Hello, did you find a solution for this problem ? It seems that I have a problem with similar symptoms. Thanks in advance. Stefan
