Bookmark
Subscribe
1181
LMS 2.6: ICServer crash?
yjdabear
I was checking to see why the Inventory Collection "failed" after scanning only 48 devices, even though no specific device was shown as "failed".
Start Time: Aug 22 2007 22:33:05 EDT
End Time: Aug 23 2007 04:06:37 EDT
Duration: 5 hours, 33 minutes, 30.56 seconds
Average Scan Time: 6 minutes, 56.876 seconds/device
Job Result Description: Timed out. Make sure that ICServer is running.
pdshow output:
Process= ICServer
State = Administrator has shut down this server
Pid = 0
RC = 1
Signo = 0
Start = 08/20/07 01:14:39
Stop = 08/22/07 22:37:40
Core = Not applicable
Info = ICServer started.
tail IC_Server.log
[ Wed Aug 22 22:36:37 EDT 2007 ],INFO ,[Thread-20],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,194,Started processing device Name: 172.18.23.12
[ Wed Aug 22 22:36:38 EDT 2007 ],WARN ,[Thread-14],com.cisco.nm.rmeng.util.logger.XDILogger,67,com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ContainmentAGI_STACK_Mib,getModuleValues,1201,Illegal Access. NoSuchInstance being accessed as Integer.
[ Wed Aug 22 22:36:38 EDT 2007 ],INFO ,[Thread-14],com.cisco.nm.rmeng.util.logger.XDILogger,77,com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ImageAGI_CISCO_IMAGE_Mib,g$eval,62,com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch:ImageAGI_CISCO_IMAGE_Mib:g$eval:populating ImageAG attributes, begins...
[ Wed Aug 22 22:36:41 EDT 2007 ],INFO ,[Thread-14],com.cisco.nm.rmeng.util.logger.XDILogger,77,com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch.ImageAGI_CISCO_IMAGE_Mib,g$eval,71,com.cisco.nm.xms.xdi.pkgs.SharedInventoryCatSwitch:ImageAGI_CISCO_IMAGE_Mib:g$eval:populatingImageAG attributes, completed
[ Wed Aug 22 22:36:44 EDT 2007 ],INFO ,[Thread-13],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,239,DP time is 32 seconds for xx.xx.xx.xx
[ Wed Aug 22 22:36:58 EDT 2007 ],INFO ,[Thread-17],com.cisco.nm.rmeng.inventory.ics.core.CollectionController,239,DP time is 40 seconds for xx.xx.xx.xx
[ Wed Aug 22 22:37:28 EDT 2007 ],FATAL,[Thread-13],?,?,Fatal Error has Occured, exiting ICServer java.lang.OutOfMemoryError
[ Wed Aug 22 22:37:34 EDT 2007 ],INFO ,[Thread-13],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,482,Total Memory :132907008
[ Wed Aug 22 22:37:34 EDT 2007 ],INFO ,[Thread-13],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,483,Free Memory :564432
[ Wed Aug 22 22:37:34 EDT 2007 ],INFO ,[Thread-13],com.cisco.nm.rmeng.inventory.ics.server.InvDataProcessor,484,Max Memory :132907008
It looks like ICServer has crashed. Is this a softwarre of hardware issue or a one-time anormaly?
David Stanford
How much RAM in this server?
you might want to try increasing the heap size:
1. Please, stop Daemon Manager, issuing the following command:
# /etc/init.d/dmgtd stop
2. Please wait 10 minutes. After that, make sure that no LMS process is
running (you can check it by issuing a "ps -ef | grep CSCOpx" command).
3. Make a backup of the following file, creating a dmgtd.conf.bak file
in some other folder in your server:
/opt/CSCOpx/objects/dmgt/dmgtd.conf
4. Edit the /opt/CSCOpx/objects/dmgt/dmgtd.conf file and search for the
ICServer entry
To increase the heap size, please update
/opt/CSCOpx/objects/dmgt/dmgtd.conf. Inside this file search for
ICServer. It will be something like
/opt/CSCOpx/bin/cwjava ... -Xmx128m
...com.cisco.nm.rmeng.inventory.ics.server.ICServer
Change the -Xmx128m value to -Xmx256m to double it and save the file.
5. Start Damon Manager and wait for 10 minutes in order to let all the
processes to start properly.
There's 16GB of RAM. The server is shared with another app with an Oracle db backend.
I won't be able to try this right away, but looking at the section you specified in dmgtd.conf, there's also an "-Xms128m". Does that need to be changed as well? Are there any published guides on tuning such parameters in dmgtd.conf?
ICServer y n 0 EssMonitor,RMEDbMonitor,RMECSTMServer /opt/CSCOpx/bin/cwjava -cw
/opt/CSCOpx -cw:jre lib/jre -server -Xms128m -Xmx128m -cp:p MDC/tomcat/shared/li
More specific, here's what you'll want to change:
For Args variable change the value from:
-Xms128m -Xmx128m
To
-Xms256m -Xmx256m
change 128 to 256 in each instance
