LMS 2.6 Packages for RME 4.0.6
dosic
There is LMS 2.6 with RME 4.0.6.
We've devided to install CBS3000.RME40.v4-2.zip for the HP blade 3020.
According to the documentation this package has several dependancies among them there is SharedInventoryStack.RME40.v1-2-1.zip.
I can not find this file.
For the first  package  (SharedSwimIOS.RME40.v1-11-7.zip) package another second package (SharedSwimRtr800.vRME40.v1-6.zip) should be installed first.
But in the doc for the second package (SharedSwimRtr800.vRME40.v1-6.zip) I see that it is dependent from first one.
Which of these files should be installed first?
And where can i find SharedInventoryStack.RME40.v1-2-1.zip?
May be there is another way for solving this problem?
Svetlana Radzevich
Just download both of them to the same directory and use PSUCli command to install all packages from that directory. This command has option "all" so it will take care about the right order for you. If you still miss any packages you will see the missed packages in the output of the command.
Format of the command should be:
$NMSRoot\bin> PSUCli -p rme -i -src -all
Svetlana, hello.
Thanks for your advice. I'll try.
Any ideas about SharedInventoryStack.RME40.v1-2-1.zip file?
This package is not on cco. I think it is part of the standart installation.i.e. it was installed with RME 4.0.6.
To verify that you already have this package you could use the command:
$NMSRoot\bin> PSUCli -p rme -pver SharedInventoryStack
To see all installed packages in RME you could use the command:
$NMSRoot\bin> PSUCli -p rme -pver -all
hello, Svetlana
current version is
Package              Version
SharedInventoryStack 1.2
But I need v1-2-1.
Would you be so kind to tell how it is possible to update it?
