LMS 3.0.1 Master / Slave upgrade
khawajajawad
We have two LMS servers 3.0.1 deployed in Master/Slave mode. And are working properly. But we are unable to add Cisco rtr2900 series router for its configuration managemnet.Current RME version is 4.1.1.
I want to go for a device update online or can be downloaded in psu_download folder. I have a confusion that
  • Should I upgrade Common Services (RME devices list) in the same Master/Slave mode or i need to setup both in standalone mode. Which one should be preferred.
  • Will it be enough to update RME 4.1.1 device list in LMS 3.0.1 or i must go for RME 4.3 (which requries all packages updates i mean LMS 3.2) becuase Cisco 2951 Router and Cisco 2911 Router can be added to current version of RME 4.1.1 by online update to CISCOWORKS LMS 3.0.1 and Cisco 2921 Routers and Cisco 2901 Routers can be added the updated version of CISCOWORKS LMS 3.2. Our requirement configuration mangemnet of Cisco rtr2901 and Cisco rtr2911
Supported Device List for LMS 3.2
http://www.cisco.com/en/US/partner/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html#3.0.1-27
Supported Device List for LMS 3.0
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0.1/device_support/table/lms301sdt.html
Thanks & Regards
Michel Hegeraat
Level 7
Level 7
You should upgrade RME software on both machines and update the devices packages on both machines.
This is not related to if the are master or slave from a DCR point of view
Cheers,
Michel
