04-08-2009 01:50 AM
Hi there,
I've a problem with generating and eMailing Quick-Reports in PDF-Format.
- I created a Interface Utilization QuickReport for all polled devices
- The shown report is good with directly viewing it
- Unfortunately with selecting attach report the only format sent via mail is csv.
- In Help it is stated that if emailed-pdf reports are required one have to select add full report, but indeed this does attach a report for all selected instances and not only the top10/botton10 instances.
Could this be a bug/design-error?
What we would like to have is a emailed pdf-report showing the top10/bottom10 elements and not the whole bunch of instances.
Thanks for any hint and tip
Lothar
04-08-2009 05:20 PM
This looks like a doc bug to me. The attach option should give you a PDF of the tabular instance data. However, it provides a CSV report instead. The full report option appears to be working as designed in that it gives you everything seen in the Quick Report you see in the GUI.
04-08-2009 09:06 PM
Hi Joe,
thanks for the update.
Do you know if the is a filed bug or enhancement-request for "emailed-pdf-report" options?
For us the CSV-Version of the reports is not suitable, as reports should be presented to higher level executives.
Will there be enhancements in reporting-output in HUM 1.2 (that might be integrated in LMS 3.2)?
Thanks for your update
Lothar
04-08-2009 09:10 PM
I will be filing a doc bug later today. There would need to be a PERS filed to track the need for a PDF option that just gives the top and bottom 10. In the meantime, you could transform the CSV into something more attractive in something like Excel.
I haven't seen any changes to the HUM email attachment feature in LMS 3.2 beta.
04-09-2009 09:18 AM
I filed CSCsz01572 to track the documentation issue.
