09-11-2009 11:49 PM
We have LMS 3.1 installed and configure IPM threshold setting on rtt.Now it notifies violation to LMS server on IPM screen whenever there is any violation occur but at the same time i want my switch will send the same trap to my third party syslog server.Please let me know which are the additional command and additional required to do in switch?
09-12-2009 08:53 AM
Trap or syslog? If syslog, you need to enable:
ip sla logging traps
If SNMP traps, then you need to make sure you have ip sla (or rtr) traps enabled for your trap host:
snmp-server enable traps ipsla
snmp-server host 10.1.1.1 traps public ipsla
09-16-2009 09:04 PM
Thanks jClarke
your advice resolve my issue.i want to enable traps on switch.now i will able to get ip sla traps on my syslog server.
thanks once again...
