LMS 3.2.1 netconfig error
raza555
Level 3
Level 3
I am using LMS 3.2.1, and while deploying the configuration to the device via Netconfig job, I receive below error message. All commands deploy successfully but Netconfig job status always failed because of below error message;
Command(s) failed on the device TFTP: Failed on the device.
However I can sync archive the same devices successfully.
Transport Settings->Archive management = SSH TELNET TFTTP RCP
Transport Settings->Config Deployment = SSH TELNET TFTTP
Please advise how to rectify the issue.
AFROJ AHMAD
Hi Rizwan,
You are using system defiend templates to push the Netconfig job or you are using the ADHOC option ?
If you are using system defiend templates use the ADHOC job and see if it makes any difference.
I remember there were few bug on this issue ,I found one :
CSCeh40578    netconfig reports success on failure
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Rizwan,
Thanks-
Afroz
Thanks Afroj,
I have tried he ADHOC command and was still getting the same error, but user answer has given me confidence that its a known bug.
Also I have noticed that although I am getting the error message, its just a cosmetic message, configurations are completely implemented by the netconfig job.
