LMS 3.2 - Campus MGR. 5.2.1 Usertracking problems resolving DNS Names
jelose
I am running LMS 3.2 with Campus manager 5.2.1 on a pretty fast system. After upgrading to 3.2 i have problems resolving some of ipadresses collected by UT to DNS names. Sometime it works and sometimes it dont. The Sunmachine i am running on is setup to first look in local host file, and after this query the DNS. If i query the DNS from a CLI on the server it works perfect. I think this maybe related to some performance issue on the DNS but i am not sure. I am normally tracking around 43000 Endhosts on a major aquisition. Has anynone experienced something like this or have you got any good ideas to solve it..?
Best Regards
Jesper Lose, Denmark
Michel Hegeraat
Level 7
Level 7
You may wish to try to use multiple threads for DNS
Under Campus Usertracking ->  Administration -> Acquisition -> Acquisition Settings -> Advanced
There is a unilty called "Lookup Analyzer" you should use to see what goes wrong
Look it up in the help under campus
Cheers,
Michel
Thx, for your answer....
I have played with Multiple threads, with no luck.
I will look into the Lookup Analyzer, and see what happens..
Best Regards
Jesper
