NetFlow
jgeruntho
What is the quickest method to verify that netflow is available on a
switch or router? We have IOS 12.4 on a 2821 router.
yjdabear
Quickest? IMO, type "ip flow-export destination" in global config mode and see if IOS complains.
Don Jacob
Check from the interface config if the command 'ip flow ingress' or 'ip route-cache flow' is accepted. As far as I have seen, this device supports NetFlow export.
And if it is just 1 device, try the Manage engine NETFlow Analyzer for monitoring. Has a free edition that lets you monitor 2 interfaces.
Jacob
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
