LMS 3.2 Device update
bszemethy
When I check for new device update at cisco.com, I got these lines at psu.log - attached.
Is this a bug?
Balazs
AFROJ AHMAD
Hi ,
Replace the attached file (vds.properties) from the below location :
C:\Program Files\CSCOpx\lib\classpath\com\cisco\nm\xms\vds
then Restart the Daemon Manager ..
NOTE : Please take the Bcakup of your Existing file (vds.properties)
--Then   go to common service > software center > device update >>   check for the Device Pcakages , you will be able to see   the Device Packages now..
Thanks--
Afroj
If this post answers your question, please click the "Correct Answer" button"
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
