LMS 3.2/ Hum 1.2 - Duplicate job views completed
richard.tetu
Does anybody has already saw that this default under a bug ?
It concerns Hum 1.2 /LMS 3.2
In the Current Admin/System preferences settings in HUM , the quick report job type "Interface avalaibility" is enable, every hour..
In the Common Services Job , recently completed, 2 jobs have been instancied , at same time, for this quick report.
Richard.
From the server's command line, run:
NMSROOT/bin/cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
From the jobcli prompt, type:
delete 4298
Then exit the jobcli interface, and restart Daemon Manager.  The job should be gone.
6 Replies 6
Joe Clarke
Post a screenshot illustrating what you are seeing.
Hello, Joe,
Please see hereafter an example of  screenshots, taken.
In this example, it's for threshold violations.
I have remarked the same issue for others jobs launched, like in my first remark.
Richard
delete 4298
Thanks for this answer.
Question: does it works for LMS 2.6 ?
Richard
Sorry, I did a research on the CISCO support web site , i found that it worked too for LMS 2.6 thanks.
Richard
Yes it does, but HUM doesn't exist in 2.6.  Deleting jobs using this interface should only be done as a last resort if the jobs cannot be removed from the GUI directly.
