05-28-2010 03:16 AM
Does anybody has already saw that this default under a bug ?
It concerns Hum 1.2 /LMS 3.2
In the Current Admin/System preferences settings in HUM , the quick report job type "Interface avalaibility" is enable, every hour..
In the Common Services Job , recently completed, 2 jobs have been instancied , at same time, for this quick report.
Richard.
Solved! Go to Solution.
06-01-2010 10:25 AM
From the server's command line, run:
NMSROOT/bin/cwjava -cw NMSROOT com.cisco.nm.cmf.jrm.jobcli
From the jobcli prompt, type:
delete 4298
Then exit the jobcli interface, and restart Daemon Manager. The job should be gone.
05-30-2010 10:41 AM
Post a screenshot illustrating what you are seeing.
06-01-2010 06:12 AM
06-01-2010 10:25 AM
delete 4298
06-02-2010 04:55 AM
Thanks for this answer.
Question: does it works for LMS 2.6 ?
Richard
06-02-2010 07:01 AM
Sorry, I did a research on the CISCO support web site , i found that it worked too for LMS 2.6 thanks.
Richard
06-02-2010 07:47 AM
Yes it does, but HUM doesn't exist in 2.6. Deleting jobs using this interface should only be done as a last resort if the jobs cannot be removed from the GUI directly.
