LMS 3.2 - Issue with Sync Archive
Prasan Venky
Level 3
Level 3
Hello Everyone,
"CM051 Vlan Running Config Fetch Failed For x.x.x.x Cause:Command FailedTelnet:Failed to establish telnet connection to x.x.x.x-cause connection refused.
Vlan config job not supported using TFTP
Vlan config job not supported using SCP"
I am getting this error while running sync archive job. While fetching configuration LMS tries using Telnet and TFTP. How can i make it to SSH and TFTP..?
Where i should configure in LMS..?
KVS
Martin Ermel
here you can define the transport protocols:
    RME > Administration > Config Mgmt > Transport Settings
be aware that you can define these settings for the different applications from the drop-down box (i.e. Archive Management, Config Editor, and NetConfig) and that the protocols choosen will be tried from top down if one fails.
see the user guide for details:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/config.html#wp1133469
Thanks for your reply.
If i create sync archive job, the job fails but config is archived for the same device.. what could be the reason..?
