LMS 3.2: Report Analysist HUM
saifmohdali
Hi all,
i got problem to explain to my boss which this related to reports from Ciscoworks HUM.
the graph of availability shows that between 21 - 28 April, the switches got problem which are indicated as "less than 1.0".
is that proven the switches got down-time?
I'd confused because on that days the switches was not reported "down".
can someone help me out?
Michel Hegeraat
Level 7
Level 7
If you see the sysuptime on the device has not restarted at the time of the dip then the device was only unavailable , but not down.
You may want to find out why the LMS was unable to poll the device.though.
Cheers,
Michel
