LMS 3.2 & Sync Archive Failure
bm_5789
I am setting up a cisco 3750 with aaa authentication along with a username and password for local access.  I just realized that my LMS will fail when performing a sync archive.  Reason for failure is TELNET: Failed to establish TELNET connection to xxx.xxx.xxx.xxx  - Cause: Authentication failed on device 3 times.  This work previously when I had telnet configured for access.  Does anyone know what I am missing.  I plan to deploy aaa authentication to all my cisco devices.  TIA
AFROJ AHMAD
share the screen shot of the login prompt of the device . Use PUTTY Only.
also share the file
TacacsPrompts.ini file [NMSROOT\CSCOpx\objects\cmf\data]
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
