Bookmark
Subscribe
1486
LMS 3.2 unable to add devices to DCR.
Not able to add device into DCR.i am trying to add device manually after pressing the finish button device addition status summary not shown .even device not shown in the DCR.
LMS is not integrated with ACS.
Please suggest how to proceed??
Thanks in advance..
Channa
2 Accepted Solutions
AFROJ AHMAD
Hi Channa,
Kindly apply the Patch for this bug, CSCtd07131.
You can downlaod the Patch from cisco.com , I hope this will fix the issue
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi channa,..
During the Patch Installation ..it will stopped the Daemon Manager automatically..
Afroj
8 Replies 8
AFROJ AHMAD
Hi Channa,
Afroj
HI Afroj,
Thanks for the reply.
I have got the patch for this from cisco .can u pls let me know how to install this patch.
i found the ctm.jar file and perl script file in it.
Do i need to shut the dmgtd before installing this patch.???
Channa
Hi Channa,
You need to browse to the location where you have saved the Patch.
I have attached a screenshot with the same but a different Patch. , I hope this will help..
Afroj
Thanks Afroj..
no need to shut the deamon manager...right??
Channa
Hi channa,..
Afroj
Thanks Afroj..
Channa
Hi Afroj,
Patch installation worked..i am able to see devices in DCR now.
Thanks alot..
Channa
Hi Channa,
Thanks for the update
If this post answers your question, please click the "Correct Answer" button"
Afroj
