LMS 4.0.1 supported ESXi Versions
david
LMS 4.0 guide states that ESXi4.0 is supported.  Anyone know if ESXi 4.1 is supported under LMS 4.0.1.  Can't see anything in the readme file around ESXi versions, Only details on Windows OS.
Many Thanks
Marvin Rhoads
According to the Installation Guide, LMS 4.0 does support VMWare Server ESXi 4.1.
Hope this helps.
Marvin Rhoads
Hope this helps.
david
Many thanks. Just what I was looking for.
