12-14-2010 04:10 AM
We have problems with ANI Server on a recent LMS 4.0 installation, the process appears with the state " Running with busy flag set" (always looks like on the same state), and we can connect with the service topology pluging and I can see topology maps, etc. But the problem appears when we try the access to any ANI Server Report (ANI Server Analisys for example although happens with the others reports) we obtain always a notification windows with the following error message: "Unable to load properties from server. Please try after some time".
If we try running the reports from local server (to avoid any problems related to the client computer) we obtain the same error.
We make some test:
A similar think happens when access to "Data collection Critical Devices Poller" whe obtain a notification windows that says that the "Ani Server may be down..", maybe are related?
12-15-2010 07:04 AM
If the aniserver is running in a pdshow then the first thing to check is the hostname of the server.
On the client pc it must resolve to the servers IP address
can you do a http://
if that is OK then do a telnet telnet servername 43242
Cheers,
Michel
12-17-2010 08:15 AM
Thanks Michel
Yes, I can connect from any client PC to the web server (the DNS name is resolved vi hosts file on all clients PC) and the tcp port 43242. Also with pdshow ANIServer I can see that the process are UP:
Process= ANIServer
State = Running with busy flag set
Pid = 20324
RC = 0
Signo = 0
Start = 12/15/2010 7:13:56 PM
Stop = Not applicable
Core = Not applicable
Info = ANIServer started.
The problem is that I cannot exec any Report from Best Practices (I obtain a error windows that said that ANI Server is not running) and cannot exec any report from "Reports>System>" .
But I can connect with Topology Services java pluging.
12-18-2010 06:18 PM
Post the ani.log, ANIServer.log, NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
12-20-2010 02:53 AM
12-20-2010 11:23 AM
It appears your installation may be damaged. Post your NMSROOT/MDC/tomcat/conf/server.xml file as well as screenshots of the Services control panel showing all of the CiscoWorks services.
12-21-2010 12:31 AM
12-21-2010 09:30 AM
Post the list of files under NMSROOT/htdocs/ANI.
12-21-2010 01:56 PM
12-21-2010 09:09 PM
On the server itself, login to LMS, then change your URL to:
http://madcpd02cw:1741/JSP/CAMPUS/ANI/GetAniName.jsp?dmgrName=ANIServer
What do you see?
According to the logs many files are "missing" when the server attempts to communicate with itself. The URL above is one such example. This could mean that the server's hostname is wrong, there's some host-based security software performing filtering, or there is some kind of permissions problem.
12-22-2010 01:06 AM
12-22-2010 02:02 PM
What other software do you have installed on the server? In particular, what security software do you have installed (e.g. firewall, anti-virus, etc.)? Do you use a proxy in your network?
01-10-2011 08:13 AM
Hello Joseph,
Sorry for delay on the response, I checked the software installed on the server, but there is not any other software, the ciscoworks installation was performed on a clean instalation of the Operative System. Also I checked that the Firewall of the MS Windows 2008 are deactivated.
Attach some captures of installed programs screen, MS windows firewall status and winversion windows
Best Regards and many thanks for your help
01-10-2011 09:18 AM
01-11-2011 07:54 AM
