LMS 4.1 -- Adding larger amount of devices (>10) results in webUI freeze and not collecting Inv/Conf-Data
lo.mueller
Hi all,
with LMS 4.1 running on solaris 10 I discovered the follwing.
Adding larger amount (>10) of devices one after the other (via DCRCLI) results in IC_Server no longer collecting the Inventory-Data nor ArchiveMgmt will collect Configs and after some while DataCollection (ANI) will get stucked in endless loop.
After that (navigating in CW2k-WebUI) the UI freezes.
Is that a known problem with Interprocess-Communication and Eventbus in LMS 4.1???
Any feedback is welcome.
Best Regards
Lothar
lo.mueller
After stopping the system I discovered that RmeDbEngine won't stop.
Issuing dbstop command also results in RmeDbEngine still running.
We had to kill process with signal 9.
