You should check if there is any error in daemon.log when you try to start the DCRServer.
Was there any change related to hostname on server?
Try to regenrate the SSL once, Please try the following steps:
1. Stop the daemon manager
2. Regenerate the SSL certificate (Dont forget to start you shell/command prompt session as Administrator):
*Remove server.* files under NMSROOT\MDC\Apache\conf\ssl (take backup of all 4 files before deleting).
*NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -disable
*NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -enable
*Fill all the details it request for.
*Ensure that the following files are created under NMSROOT\MDC\Apache\conf\ssl :
server.crt
server.csr
server.key
server.pk8
-Thanks
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
