LMS 4.1 feature quires
kernmartis
I need to know if LMS 4.1 support the below option:
  1. If any change in the configuration      of switch or route is done. Can the LMS be configured to mail/notify the      changes made by which login to a predefined Administrator mail id.
  2. Can't it give latency report      (SLA management)?
  3. Can it provide notification      on CRC errors on any WAN links?
Kern
Michel Hegeraat
Level 7
Level 7
All these features are possible but require configuration.
1 a change will be detected and a mail can be send with a device name. A device center page can then show the last change
2 IPSLA renamed to performance can provide this
3 DFM (Fault) will raise an alert when CRC goes above a threshold.
Cheers,
Michel
