LMS 4.1 running on VM very slow
ReadersUK
Level 2
Level 2
Im running LMS 4.1on a VM, it runs very slow, does anyone know what specs my vm should be running to support this application?
col
ngoldwat
Level 4
Level 4
Here is the document you are looking for.
LMS 4.1 supports the following Virtualization Systems:
•  VMware ESX server 3.0.x
•  VMware ESX Server 3.5.x
•  VMWare ESX Server 4.0.x
•  VMWare ESX Server 4.1
•  VMWare ESXi Server 4.0
•  VMware ESXi Server 4.1
•  Hyper V Virtualization (As an installable in Windows 2008)
Component
Recommended Requirement
  VMWare ESX server 4.1
  VMware vSphere Hypervisor (ESXi server 4.1)
Hard disk space
256 GB
Memory and CPU Requirement
  4 GB, 2 virtual CPU (< = 500 devices)
  8GB, 4 virtual CPU (< = 1500 devices)
  16GB, 8 virtual CPU ( > 1500 devices)
Swap space
32 GB
Host CPU Core clock speed
Minimum 2.26 GHz
Minimum Virtual CPU Reservations
Number of recommended virtual CPUs x 2.26 GHz:
  4520 MHz (< = 500 devices)
  9040 MHz (< = 1500 devices)
  18080 MHz ( > 1500 devices)
Resource Memory Configuration
  4096 MB (< = 500 devices)
  8192 MB (< = 1500 devices)
  16384 MB ( > 1500 devices)
aparada14
I have LMS 4.1 running on VM too, and sometimes some features of LMS are very slow, I would like to make you a question, all the proccess are running in a good status?
