LMS 4.2.2 DOT1X Report
Hi, i need a lms report to know if service dot1x  on the switchs in my lan is enable.
Thanks a lot.
Emiliano
Marvin Rhoads
I believe that's a subset of the Trustsec report. If not, you could create a compliance report looking for the necessary string(s).
Thank you for your answer, but I need not have a report or PC user who authenticates dot1x but if the service is enabled. example:
a report that show dot1x: enable or disable
Emiliano
The report I was thinking of is actually the TrustSec Readiness Assessment which shows you which devices are capable of having 802.1X features enabled.
