01-11-2013 08:35 AM
I have upgraded to prime LMS 4.2.2 (from 4.0.1) and can not perform system or device upgrade. Using wireshark I can see why. it looks like LMS is trying to go to this old web link http://cco.cisco.com/cgi-bin/login to get software. I believe this was fixed years ago in bug CSCto46927.
Can I reapply bug fix CSCto46927 on 4.2.3 or is there another fix?
Thanks.
01-24-2013 04:21 AM
Hi all,
I am running LMS 4.1 and facing the same issue. I suppose that this too is affected.
Waiting for any update
01-24-2013 07:36 AM
Hi all,
I just upgraded to LMS 4.2.3 from 4.2.1 because I thought doing so would resolve the issue preventing me from connecting to cisco.com for updates. I keep getting the "No proxy host configured" error in the psu.log.
Thu Jan 24 09:28:37 CST 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
[ Thu Jan 24 09:28:40 CST 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
[ Thu Jan 24 09:28:40 CST 2013 ] INFO [SecurityHandler : getCSProxyPort] : No proxy port confgured
I don't use a proxy server. I remember once upon a time I could update LMS, so what gives?
Thanks in advance for any info.
-Chris
01-24-2013 07:45 AM
Hi All ,
Issue is still not resolved , I am hoping that it will be resolved in couple of days ..
This issue is affecting All LMS versions
Afroz
01-24-2013 03:11 PM
Just a quick update for everyone, the issue is still present and the Cisco team is still working to resolve it. No ETA for a resolution is available yet.
While this is resolved you can get updates for the application directly on the cisco.com page:
http://software.cisco.com/download/navigator.html?mdfid=283427841
-Mari
01-29-2013 08:00 PM
I'm running 4.2.3 and the device and software updates worked today.
01-29-2013 11:55 PM
I'm running 4.1 and the problem seems to be fixed
01-29-2013 11:59 PM
As the issue was mainly NOT from the device side and was from Cisco.com URL used by server's.
It is fixed now and the issue should resolve for all the LMS server's.
-Thanks
01-30-2013 02:23 AM
"It is fixed now and the issue should resolve for all the LMS server's."
Are you sure?
The error message is missed, so I asume the web page is answered correctly,
but something is wrong with package checking.
For example, at my LMS 4.2.3 the ASA package is 7.0. After checking it shows there is no package to update (Popup - "No updates available in Cisco.com for selected products")
Tcpdump shows:
So there is an update to 7.1. Same problem with NAM (my ver is 6.0) and the newswest at cisco.com is NAM 6.1,
On the other hand the "
If a have a newer (patched) version, the packages are not available to me??
Dont understand...
01-30-2013 03:25 AM
Hi, looks like its a bit unstable right now, sometimes upgrade works, sometimes it doesnt.
Linux appliance LMS 4.2.2
01-30-2013 07:15 AM
Hi All,
Yes the issue is been taken care It will be stable in next 24 hour !!!
Cheers !!!
Afroz
01-30-2013 11:10 AM
I"m running LMS 4.2.3 and updates are still not working for me.
from psu.log:
[ Wed Jan 30 13:24:15 CST 2013 ] INFO [SecurityHandler : getCSProxyPort] : No proxy port confgured
[ Wed Jan 30 13:24:15 CST 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
I'm not using a proxy!
-Chris
01-30-2013 03:24 PM
Running 4.2.3, this is still not fully fixed
I can run the update for Device, but as I did some manual uupdates it reports no updates to apply.
How ever rge update for Ciscoview is still broken, with the No Proxy fault.
[ Wed Jan 30 23:20:01 GMT 2013 ] FATAL [DevUpdate : performAdd] : Error while trying to connect to Cisco.com. Return Code = 1
[ Wed Jan 30 23:20:01 GMT 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
[ Wed Jan 30 23:20:26 GMT 2013 ] INFO [SecurityHandler : getCSProxyLogin] : No proxy User Name configured
[ Wed Jan 30 23:20:26 GMT 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
[ Wed Jan 30 23:20:30 GMT 2013 ] INFO [SecurityHandler : getCSProxyHost] : No proxy Host configured
[ Wed Jan 30 23:20:30 GMT 2013 ] INFO [SecurityHandler : getCSProxyPort] : No proxy port confgured
02-02-2013 10:04 PM
Hi All ,
Cisco.com connnectivity issue has been fixed now. It is stable now.
Afroz
02-04-2013 05:37 AM
Are you sure?
Pls take a look at my (Jan 30, 2013 3:23 AM ) post,
We have 4.2.3 , the installed ASA package is 7.0. After checking it shows there is no package to update (Popup - "No updates available in Cisco.com for selected products"), but tcpdump shows the 7.1 is available.
02-04-2013 12:38 PM
Attila - my LMS 4.2.3 successfuly updated ASA software to version 7.1.
