LMS 4.2.3 Fault Monitor threshold question
cwallin
Hello, I would like to know if anyone know how to find out which Fault Threshold group a specific interface belongs to.
The scenario is that in Fault Manager there is an alarm for which I want to change the Threshold Setting.
Example Alarm:
Event_Description HighUtilization
Device IP x.x.x.x
Device Type Routers
Fault Last Updated At 19-Mar-2013 09:44:25
Component IF-router2.x.x/26 [Tu187] [x.x.x.x]
Component Class Interface
Component Event Code 1056
Current Utilization 68.323204 %
Duplex Mode FULLDUPLEX
Event Category Utilization
Event Source DFM
If Description Tunnel187
Max Speed 100000
Traffic Rate 8540.4 BYPS
Type TUNNEL
Utilization Threshold 40
If I look in Monitor > Fault  Settings > Setup > Threshold  Settings.
Then expand all groups under DFM, there is no group called "Tunnel", so the question is which group this Interface belongs to?
BR /Crille
Nael Mohammad
Level 5
Level 5
Its defined as an 10/100 ethernet interface " Component Class Interface"  with a 40% threshold utilization which it fell below per the event notifiation of 68.3%.
If Description Tunnel187 --> Interface on router
Max Speed 100000 --> Interface type(Fast Ethernet)
