LMS 4 Devices added but not shown in inventory
balmain99
By reruning discovery with new seeds etc I have more devices discovered.
Howeverr they are not shown in the inventory, only in the Device Discovery Summary however.
Any help, is welcome.
10 Replies 10
Gaganjeet Chug
Level 4
Level 4
Does the last discovry shows any figure after "Devices Newly Added to DCR"  ?
If its, kindly check if you are able to view them at Inventory > Devcie Administration > Add/Import Manage devices.
Gaganjeet
Thanks for your reply,
The discovery shows:
Total Devices              164
Reachable                  155
Unreachable               105
Newly added to DCR     11
Updated to DCR          144
The Hardware Summary shows 112
and where you mention above it shows 164.
Thanks again.
Ok, so that means device have been added successfully, kindly let me know where you wont be able to see them, if possible with the screenshot.
Gaganjeet
Pls see attached file it shows 116.
Kindly share the screenshot of Inventory > Dashboard > Device Status.
Gaganjeet
Please see attached the pertinent portions of the requested screen.
Thanks again.
It looks like overall database of Inventory collectiona and sync archive is not synchronized too.
Kindly share the screenshot of  :-
Inventory > Device Administration > Add as Managed Devices (Check if you see any devices under All Devices)
Inventory > Device Administration > Device Allocation Policy
Inventory > Device Administration > Device Aliases
Gaganjeet
Thanks again for reviewing this message.
Please see below attached print screens.
Kindly go to Inventory> Job Browsers> Inventory Collection and create new job for all the devices. Kindly note down the numbers of devices selected for the job.It should show up all the 164devices there.
Gaganjeet
I'm having the same issue. I've created an inventory collection job and it's showing 105 devices. However, they are still not showing under inventory.
Anything else I can check to make sure that I haven't missed anything?
