LMS + CDP filter
srkala
I want to filter certain CDP ID's. I want to know where should I make the changes, in system-config.xml or CSDiscovery-config.xml?
Michel Hegeraat
Level 11
Level 11
Thanks for the response Michel,
I've gone through the document and it looks like the changes have to made in
system-config.xml file. But if you go to "Discovery Configuration File" in the same document
https://supportforums.cisco.com/docs/DOC-9005#Discovery_Configuration_File
It says the changes will be stored in this file and it can be edited using text editor. So I want to be sure before editing anything. Also if you can explain the difference between the system-config.xml and CSDiscovery-config.xml it'll be really helpful.
Sri
Hi Team,
I think I have found my answer in another thread :
https://supportforums.cisco.com/thread/2059244
