12-27-2005 01:16 AM
Please can somebody help me in Cisco Works (LMS)
I have install the all this service in LMS2.5
1. Common Services
2. Cisco View
3. Resource Manager Essentials
4. Campus Manager
5. Device Fault Manager
6. Internetwork Performance Monitor
and now in my network i have one pix firewall and one switch ....
So please help me that how i can manage this device in LMS 2.5
My EMail ID is linux_ccnp@yahoo.co.in
12-27-2005 03:20 AM
Hello Shailesh,
start reading here:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000_b/lms/index.htm
This will extend your knowledge to manage these two devices.
Best regards,
Frank
12-27-2005 01:40 PM
Starting with version 2.5 Cisco Works LMS uses a common database for all devices.
There are several methods of entering devices
1) Manually add them
2) Use auto discovery (remember to set a seed device - oh an this works best if you have CDP enabled)
#1) To manually add a device, log into Cisco works, go to Common Services => Device and Credentials => Device Management. Click the add button and input the information about your devices. Once completed you more then likely want to inventory the device to get information about it into your repository. To do this go to (main window) RME => Config Management => Archive Management. In the window that pops up choose "Sync Archive", pick the devices, give it a description and hit run.
#2) Go to Campus Manager => Administration. New window go to Admin => Device Discovery. You should get if from there but its a bit slower the doing #1.
"Quick Start Guide for LAN Management Solution 2.5" link can be found at
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/products_quick_start09186a008036dfa9.html
Andy
