LMS MIB
georgeef1
Level 4
Level 4
Is there a way we an creat MIBs and we can link it with CiscoWorks to monitor the information it will provide?
-Thanks
Joe Clarke
If you have the Health and Utilization Monitor add-on installed, you can load MIBs into it, and then create custom templates and pollers to monitor required OID values. In order to load MIBs into HUM you must first load all of the required MIBs listed in the target MIB's IMPORT clause. This must be done recursively for all dependencies.
The MIB load interface can be found under HUM > Admin > Load MIB.
