LMS Prime: Certificate Signing Request Issue
alex.dersch
Level 4
Level 4
i installed LMS Prime on a softappliance i am trying to generate a Signing Request to request a certificate from our corporate CA. I add the information under Admin > Trust Management > Local Server > Certificate Setup and pressed apply.
But only the server.crt and server.pk8 were created. But i need the server.csr file to request a new certificate. I tried using the old server.csr file but the hostname in the issued vertificate doesn't match the hostname.
Any ideas why server.csr and server the server.key were not updated?
-rwxr-xr-x 1 casuser casusers  404 Oct  8 13:00 openssl.conf
-r--r----- 1 casuser casusers 1054 Oct  8 13:00 server.crt
-r-------- 1 casuser casusers  595 Jul 18 11:59 server.csr
-r-------- 1 casuser casusers  891 Jul 18 11:59 server.key
-r--r----- 1 casuser casusers  636 Oct  8 13:00 server.pk8
alex
7 Replies 7
Michel Hegeraat
Level 7
Level 7
Have a look in CSCOpx\MDC\apache\ssl\
There are some scripts to generate normally in the same directory
Cheers,
Michel
Hi Michel,
there is no folder ssl in /opt/CSCXpx/MDC/Apache
do you refer to the windows based version of LMS?
regards
Alex
Hi Alex,
try this :
1.go to /opt/CSCOpx/MDC/Apache/conf/ssl and delete or backup the following files:
server.crt
server.csr
server.key
server.pk8
(2) Do a /opt/CSCOpx/MDC/Apache/bin/ConfigSSL.pl -disable
(3) then /opt/CSCOpx/MDC/Apache/bin/ConfigSSL.pl -enable
Enter all the information to generate the certificate (4) /etc/init.d/dmgtd stop Wait 10 minutes (6) /etc/init.d/dmgtd start
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afroj,
thanks for supporting me, i did what you recommended. In SSLUtil i got this warning
Please note the requirements below for uploading certificate(s)
** CiscoWorks requires the Certificate(s) to be uploaded in Base64-Encoded X.509Certificate format
** You should have obtained the third Party Certificate using the CSR file generated by CiscoWorks Server.
** If you have not obtained the Certificate from a Prominent third party CA, you will also have to upload the root CA certificate as part of the Certificate Chain
** It is recommended that you run this script with option '4' first to verify the Certificate(s) to be uploaded
Do you want to continue [y/n]?y
Enter the location of the Server Certificate to be uploaded: /opt/CSCOpx/MDC/Apache/conf/ssl/server.crt
INFO: Certificate is a Base64-Encoded X.509Certificate
INFO: Certificate validated with Server's Private Key successfully
WARNING: HostName in Certificate does not match CiscoWorks Server name.
HostName in Given Certificate      : nos-ch-wbn-lms1.nosergroup.lan
HostName as known to CiscoWorks: nos-ch-wbn-lms1
i guess that is because i used the full qualified domain name to create the certificate instead just the hostname. Will this cause any problems later?
regards
alex
I verified the certificate with option 4 and got this result.
[Sun Oct 09 00:51:14 CEST 2011]INFO: The Certificate Chain is Complete
INFO: The given Certificate(s) constitute a complete Chain
INFO: Input Certificate/Certificate Chain Verification Successful
INFO: The Certificate(s) can be uploaded to the CiscoWorks Server
i am little bit suspicious because i screwed recently my LMS and had to set it up again.
regards
alex
Hi Alex,
I would recommed you to generate the certificate with HostName not with FQDN.
Afroj
Hello Afroj,
i create the signing request with the hostname only. After adding the certificate and the CA certificate with SSLUtil option 6 the Apache server doesn't start anymore.
I used option 1 of SSLUtil to display the certificate information and i got this message.
*** CiscoWorks Server Certificate Information ***
unable to load certificate
8534:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:650:Expecting: TRUSTED CERTIFICATE
Use of uninitialized value in scalar chomp at /opt/CSCOpx/MDC/Apache/bin/SSLUtil.pl line 739, line 1.
Use of uninitialized value in scalar chomp at /opt/CSCOpx/MDC/Apache/bin/SSLUtil.pl line 745, chunk 1.
Use of uninitialized value in substitution (s///) at /opt/CSCOpx/MDC/Apache/bin/SSLUtil.pl line 103, line 1.
Use of uninitialized value in substitution (s///) at /opt/CSCOpx/MDC/Apache/bin/SSLUtil.pl line 104, line 1.
[Sun Oct 09 20:15:03 CEST 2011]Error occurred while reading Certificate: Could not parse certificate: java.io.IOException: DerInputStream.getLength(): lengthTag=127, too big.
Error occurred while trying to validate the given Certificate
PDSHOW give this
pdshow Apache
        Process= Apache
        State  = Administrator has shut down this server
        Pid    = 0
        RC     = 1
        Signo  = 0
        Start  = 10/09/11 20:24:14
        Stop   = 10/09/11 20:24:15
        Core   = Not applicable
        Info   = Application started by administrator request.
any ideas?
regards
Alex
