LMS /tmp drive space Solaris appliance
isaacalves27
Hello
I have a small question to which I could find no answer on documentation. My /tmp partition is running out of space - 96% of 9Gb is used as you can see on the attachment bellow.
Which of these files would be safe to delete? Or should I increase /tmp space?
Best regards
Isaac
AFROJ AHMAD
Hi Isaac,
You can safely remove the core files , this will not Impact anything..
core-cwjava-6-501-500-1092-1367574752
core-sm_server-6-0-500-30903-1378213427
core-sm_server-6-0-500-8723-1373980102
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
5 Replies 5
AFROJ AHMAD
Hi Isaac,
Thanks-
Afroz
Hello Afroj
Thanks for your reply. I have deletede the files you suggested and evruthing is running fine. Thanks for your help
Do you have any docs that describe the usage of these and of the other files ont the /tmp directory? I have searched on cisco.com but couldnt find anything relevant.
Best regards
Isaac
Hi Isaac,
Ideally deleting the Tmp files should not create any issues. As such there is no doc exist specifically for this information as per my knowledge.
Thanks-
Afroz
Afroz,
I came across a customer server running low on tmp space and found almost 2000 of those core-web_server files. I'd not seen that on other installations. Do you know if there is there a bug or misconfguration that will cause them to proliferate so much?
Thanks.
Hi Marvin,
The system dump the  "memory thread" to these core files when a process crashes.
like  web_server process crashes  or sm_server
It is quite safe to delete these files to free space on the server .
Have a nice day ahead
Thanks-
Afroz
