LMS4.2: 3 fast growing logfiles - could not recognize debugging activated
STEFFEN NEUSER
Level 4
Level 4
Does anybody experienced fast growing with this logs and got a solution?
  • troubleShooting.log
  • CAMServerCollection.log
  • ConfigManagementServer.log
with some 100 entries for same second and 1GB per day. No other problems.
When I was checking the customers LMS, I could'nt not recognize that any debugging is activated from the perspective of what the GUI is telling me. How can I check that debugging is realy not activated? Are there known issues with between real debugging settings and that what the GUI shows?
many thx f hints, Steffen
AFROJ AHMAD
Hi Steffen,
Looks like NetConfig log level was enabled in DEBUG mode which in turn made "troubleShooting.log"
in GB level. Log size will grow if we access below pages in GUI with DEBUG mode.
Inventory > Dashboards > Device Status
Monitor > Troubleshooting Tools > Troubleshooting Workflows
Change the log level to INFO mode for "Netconfig" under Admin > System > Debug
Settings > Config and Image Management Debugging settings.
Note: Just like "NetConfig" check it for achive mgmt as well..
Also ,you should configure the Log Rotation of  the logs to avoid such suituations
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2/user/guide/admin/server.html#wp1055307
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Steffen,
Thanks-
Afroz
thx
