11-25-2013 10:10 AM
Does anybody experienced fast growing with this logs and got a solution?
with some 100 entries for same second and 1GB per day. No other problems.
When I was checking the customers LMS, I could'nt not recognize that any debugging is activated from the perspective of what the GUI is telling me. How can I check that debugging is realy not activated? Are there known issues with between real debugging settings and that what the GUI shows?
many thx f hints, Steffen
Solved! Go to Solution.
11-25-2013 10:54 PM
Hi Steffen,
Looks like NetConfig log level was enabled in DEBUG mode which in turn made "troubleShooting.log"
in GB level. Log size will grow if we access below pages in GUI with DEBUG mode.
Inventory > Dashboards > Device Status
Monitor > Troubleshooting Tools > Troubleshooting Workflows
Change the log level to INFO mode for "Netconfig" under Admin > System > Debug
Settings > Config and Image Management Debugging settings.
Note: Just like "NetConfig" check it for achive mgmt as well..
Also ,you should configure the Log Rotation of the logs to avoid such suituations
Thanks-
Afroz
[Do rate the useful post]
11-25-2013 10:54 PM
Hi Steffen,
Thanks-
Afroz
11-26-2013 02:43 AM
thx
