09-13-2012 03:42 PM
I have the following message in my CiscoPrime LMS 4.2.2 home portal:
Discrepancies
and
Best Practices Deviation
But when I see the Process Status Report, the process is running:
| 36. | ANIDbEngine | Program started - No mgt msgs received | 1484 | 0 | 0 | N/A | Not applicable | Not applicable | Service was already running |
Can you help me with this issue?
Kike Hdez
09-16-2012 09:10 AM
Hi Enriqueahj
have you made a ping test from a PC DOS command prompt to the LMS server Ip address???
Try ping "IP_Address" and try ping "name_serverr"
I´ll wait for your answer
09-19-2012 12:40 PM
Hi Aparada14
Yes, I can ping the LMS server with the ip address and the name_server.
I can access the LMS service via web, and I can login the service, but in the main window, I have some error messages. See the image below:
09-19-2012 01:15 PM
LMS is working on Windows Server or Linux Server or any other????
your process ANIDbEngine maybe is not running well, it has the following status in normal condition:
ANIDbEngine Program started - No mgt msgs received
try in your LMS to start up the process
09-19-2012 03:09 PM
Hi Aparada
The LMS is installed in a Windows Server 2008 Enterprise.
I restarted the ANIDbEngine process but I have the issue yet. Also, I see that ANIServer process is in "Running with busy flag set" state. Is this normal?
| 3. | ANIDbEngine | Program started - No mgt msgs received | 1488 | 0 | 0 | N/A | Not applicable | |
| 4. | ANIServer | Running with busy flag set | 12736 | 0 | 0 | 9/19/2012 3:34:06 PM | Not applicable |
