loopback interface configuration on msfc
jcook
Community Member
I have several 6500 in the same VTP domain that are used as access layer and trunk into two core 6500s with msfc.
We use vlan254 as the management vlan so all access switches have sc0 configed on that vlan.
My problem is that I can't assign an ip address on that subnet to the loopback 0 interfaces on the core msfcs. I get a error saying that "address overlaps with interface vlan254". Is there any way I can configure the loopback with an address on this vlan?
TIA,
Jason
srutledge
Community Member
If the vlan254 subnet is say 10.10.10.0 255.255.255.0
your loopback addresses could be
10.10.20.1 255.255.255.255,10.10.20.2 255.255.255.255,10.10.20.3 255.255.255.255-10.10.20.254 255.255.255.255
depending on routing confiogurations you may need static routes.
jcook
Community Member
the vlan254 subnet is actually 10.x.254.0 255.255.255.0. All of the switchs sc0 interface are 10.x.254.x.
This is why I believe I get this error. All other vlans interfaces are configured this way and there are no subnets left.
My only alternative is to use vlan1 subnet interface 10.x.1.x 255.255.255.0 which I want to avoid since it is a backplane management vlan.
Any other ideas?
Jason
srutledge
Community Member
you will not be able to use 10.x.254.0/24 for loopback addresses.
Keep 10.X.254.0 for the sc0 ip addresses
do not use 10.x.1.x 255.255.255.0
have no interface vlan1 defined for 10.x.1.0
the switch will still use vlan1 for internal use.
but use the 10.x.1.1-254 for loopback addresses
interface Loopback0
ip address 10.x.1.1 255.255.255.255
for one switch then use
interface Loopback0
ip address 10.x.1.2 255.255.255.255
for the next switch and so on
this is how we are doing it.
interface Loopback0
ip address 10.X.64.1 255.255.255.255
interface Vlan504
description MDF
ip address 10.X.80.2 255.255.255.0
ip helper-address 10.X.X.X
ip directed-broadcast
set interface sc0 504 10.X.80.5/255.255.255.0 10.X.80.255
set interface sc1 down
set ip route 0.0.0.0/0.0.0.0 10.X.80.1
