lsm 2.5 discovery 6509 problems / 2955 temp alert
simonstoll
I have two questions:
1. Why does CW LMS 2.5 dedect cat6509 Neb-A with MSCFII as a 7609 Router? That way i get lots of errors about ports which are operationaly down, which I don't want because it's a access layer switch. Is there a workaround? If I manualy change the type to cat6500 Neb-A i shows me the devices as unknown.
2. All my cat2955 shows alarms about high temperature, but the cat2955 is made for temperatures up to 60 DegC. Is there a way to tell DFM about that fact?
Any help would be appreciated, as long as it helps me solve this problems.
Simon
a-vazquez
Level 6
Level 6
I think you dont have all the latest packages required for Cisco Works. Thats the reason the device is being detected wrongly.You
could download the latest packages from the website given below.
http://www.cisco.com/cgi-bin/Software/CiscoView/cvplanner.cgi
