Managing vty ACLs with Prime Infrastructure?
Toivo
I have a number of devices -- various models of Nexus, (2k - 7k), 6500s and some 1U stackables.
I'm trying to come up with a good way to leverage PI (2.1) to apply a vty ACL to the switches. There does not appear to be a template for this. The problem of course is not only the order of operation (remove ACL from vty if there is one so Prime doesn't lock itself out, only then do the rest of the stuff) but that the syntax seems to differ very aggravatingly -- some require "line vty 0 1509," some "line vty 0 1510," some platforms accept named ACLs for vty ACLs, some don't...
Any tips, tricks, or best practices on how to install and update vty ACLs on IOS and/or NX-OS devices with Prime Infrastructure?
Brad Martin
Level 3
Level 3
I am also interested in this topic. We have vty ACLs in place but with different names. Would like to be able to find and update the ACL's and vty config. Using PI 2.1.
