Maximum fetch timeout problem
agipkcolon
RME4.0.9
Cannot change the Maximum time to wait for Job Results per device (seconds). If I enter the new time and press apply it says "New settings saved successfully." But if i refresh the page it shows the old setting - 120 seconds.
And I need to change it. Is it bug?
5 Replies 5
David Stanford
What is you version of RME? 4.0.9 does not exist
I saw this in releases prior to 4.0.5
yjdabear
Instead of refreshing the page, what happens if you click Fetch Settings on the lefthand pane again? Does it keep the new value or old 120 secs?
Joe Clarke
This is almost always a problem with regdaemon.xml. Please post NMSROOT/MDC/etc/regdaemon.xml. If the data in this file is too sensitive to be posted on an open forum, please open a TAC service request with this information.
Sorry about version. it is RME4.0.6
Yes, this file contains some sensitive information. I would prefer to create TAC Service request.
Thank you,
Askar
I manually edited this file, put new value and restarted server. It seems ok now.
Thanks a lot
