01-25-2008 04:50 AM
RME4.0.9
Cannot change the Maximum time to wait for Job Results per device (seconds). If I enter the new time and press apply it says "New settings saved successfully." But if i refresh the page it shows the old setting - 120 seconds.
And I need to change it. Is it bug?
01-25-2008 07:44 AM
What is you version of RME? 4.0.9 does not exist
I saw this in releases prior to 4.0.5
01-25-2008 07:57 AM
Instead of refreshing the page, what happens if you click Fetch Settings on the lefthand pane again? Does it keep the new value or old 120 secs?
01-25-2008 10:24 AM
This is almost always a problem with regdaemon.xml. Please post NMSROOT/MDC/etc/regdaemon.xml. If the data in this file is too sensitive to be posted on an open forum, please open a TAC service request with this information.
01-25-2008 07:37 PM
Sorry about version. it is RME4.0.6
Yes, this file contains some sensitive information. I would prefer to create TAC Service request.
Thank you,
Askar
01-25-2008 08:14 PM
I manually edited this file, put new value and restarted server. It seems ok now.
Thanks a lot
