Migrate from WCS 7.0 to Prime Infrastructure 1.2
g.peart
Hi All,
I am looking for advice on the licensing and upgrade path for going from WCS 7.0 to PI 1.2.
At present I have a WCS licensed for 200 APs which is  managing one controller and 150 APs.
I intend to use the Cisco Prime Upgrade Promotion
to order R-W-PI12-M-K9 (WCS 7.0 to Cisco Prime Infrastructure 1.2 Migration)
and L-W-PI12-100-M and L-W-PI12-100-M to match the number of licenses on the WCS.
Once Prime is installed I also want to manage another 50 devices, does that mean I have to purchase the
Cisco PI 1.2 Base License and Software (R-PI12-Base-K9) and another 50 Lifecycle licenses, or will
my existing 200 licenses from the upgrade suffice.
Sorry if it's confusing, but I didn't invent the licensing structure just trying to make sense of it all.
TIA
beecher
You'll be able to manage up to 200 devices/APs simpy using the upgrade from WCS to PI 1.2 as you described it. No need to order another base license or 50 lifecycle licenses.
beecher
Just what I wanted to hear,
thanks
