missed items in GUI interface
AbdallahMidani
hello every one
i have Cisco (C9300-24T) switch and i managing it from GUI web interface.
Previously i can see the full items like dashboard, monitoring, administration, Port Management, etc
but currently i cant see the items excepting dashboard, monitoring!! i dont know where the others items gone,
so any one have  solution for this issue, also i will attached a image for the current missed GUI interface.
Regards.
AbdallahMidani
Finally i found the Solution,
it was authentication issue
so i disabled the authentication by command (No IP HTTP Authentication)
then it was full features on the GUI including the configurations, administrations, and troubleshooting.
Thank for all
5 Replies 5
marce1000
 - Try clearing browser cache and or have test with another , but supported , browser.
  M.
thank u MR i tried to clear cache, tried another browser, another PC and i still have the same problem.
    thanks a lot.
Have any changes been made on the switch recently? Any config change or upgrade of code?
Rick
no not yet
AbdallahMidani
Thank for all
