03-29-2006 05:24 AM
Now i have few device in RME with only ip address when i look E.g. device list. Thats because when those devices was discovered they was not added to DNS.
Now devices have name and when i look DCR i can see that names are in DCR. How can i get names to RME without deleting devices from RME and adding them from DCR again. If i delete devices from RME i lost everything important.(E.g. config backups) Is there option in RME like sync all device information from DCR including device names. Any experience.
Juha
04-03-2006 06:53 AM
I think they should be listed under "conflicting devices". It should be somewhere under RME > Device Management.
There you should have the option the replace the old ones (IPs) with the newly discovered ones (hostnames)
MArtin
04-03-2006 11:22 AM
It is in RME > Devices > Device Management > Alias Devices
Check if they are listed there
MArtin
