Missing File chwp.applications.do
johnsonk1024
I recently installed a few Windows 2000 security updates that broke Ciscoworks. The error I am receiving is
HTTP Status 404 - /cwhp/cwhp.applications.do
type Status report
message /cwhp/cwhp.applications.do
description The requested resource (/cwhp/cwhp.applications.do) is not available.
Currently we are running CiscoWorks LMS 3.0 with all available pathces and updates. The login screen appears normally, but upon acceptance of our certificate we get the above message. This all running on a Windows 2000 server and the patches that were installed are
(KB890830)
(KB905414)
(KB904706)
(KB905749)
(KB896688)
(KB902400)
(KB901017)
(KB900725)
(KB899589)
(KB905495)
Has anyone else seen this issue?
Thanks in Advance
nhabib
Level 9
Level 9
If you have also installed virus scanning on your server, this might be CSCsa77791
The problem was with a bad dat file from McAfee.
