Modify Banner with EEM?
cause eem could do a lot of chances in the configuration without an operator, I want to inform the operator/admin with the content of the "banner exec" about some important system parameters.
I tried to configure some banners with eem applets, but without success.
Here is an example, section "action"
action 1.0 cli command "enable"
action 2.0 cli command "configure terminal"
action 3.0 cli command "banner exec @"
action 4.0 cli command "some text"
action 5.0 cli command "@"
action 9.0 cli command "end"
I can´t understand the problem cause writing a banner are some simple cli commands. Maybe the response of the initial "banner exec @" command is the problem? Does anyone tried it with success.
Other eem applets are running without problems on the same system.
Thilo
Joe Clarke
You need to answer the interactive prompts, or do a one-line banner.  It looks like a single line will work.  Try:
action 3.0 cli command "banner exec @ some test @"
action 4.0 cli command "end"
Joe Clarke
Hi Joseph,
I tried it in the one line banner form and it works fine.
Thanks and Regards,
Thilo
