monitor cpu on cisco cbs 220 switch
ayashour
hi when i add custom cpu sensor for the switch i got no object found
i did try adding OID Value : 1.3.6.1.4.1.9.6.1.101.1.7.0 (worked in cbs350)
and also 1.3.6.1.4.1.9.9.109.1.1.1.1.5.1 (worked on c2960x)
but they did not work
what is the OID Value for the switch CBS220
Mark Elsen
 - Could be due to lack of functionality versus the higher model (cbs350) ; check if the OID is available in
                           https://software.cisco.com/download/home/286327420/type/283965836/release/2.0.2.8
 M.
ayashour
i think the functionality is fine because i can find the cpu utilization in the gui interface
- That does not mean it is available as such in the MIBS , check the
content of the link I posted.
M.
Ditto.
